tennis4you Posted October 21, 2011 Posted October 21, 2011 I am getting the lines are not coplanar when working off of a surveyor's drawings which is testing my patience. I am using LT so I do nto believe I have access to LISP. And the other suggestions I have seen say to use the FLATTEN command which must not be a function for LT because it is unrecognized. Do I have options to flatten it? Quote
Jack_O'neill Posted October 21, 2011 Posted October 21, 2011 I am getting the lines are not coplanar when working off of a surveyor's drawings which is testing my patience. I am using LT so I do nto believe I have access to LISP. And the other suggestions I have seen say to use the FLATTEN command which must not be a function for LT because it is unrecognized. Do I have options to flatten it? There is a sequence you can put on a tool bar button that will do this for you. I'd be happy to give it to you but I'm away from home and my cad machine, and I can't remember the sequence right off the top of my head. I'll be home in a couple hours and post it for you then if someone else doesn't. Quote
ReMark Posted October 21, 2011 Posted October 21, 2011 The macro sequence is shown in post #8 of this thread. http://www.cadtutor.net/forum/showthread.php?62732-Need-quick-help-with-quot-thickened-quot-text&highlight=flatten Before you do that though you can try the original CHANGE command. Choose the ELEVATION option and set it to "0". Worth a try. Quote
