stainless
Creating a drawing border template
stainless
Want to create a drawing border, a box on the right hand side containing all the information about the drawing. I want this to be a template so each drawing I create will have the drawing border on the right. Can anyone help please???
Share this post
Link to post
ReMark
You can start with one of the default AutoCAD templates (DWT) and after making any necessary additions (layers, dimension styles, text styles, etc.) you can save it under a new name. Set QNEW to bring up this template file whenever you start a new drawing.
Share this post
Link to post
stainless
It will not let me edit any of the text on the templates??
Share this post
Link to post
stainless
I'm trying to edit a template, but it won't let me edit the text?? I want to create a drawing border. Does anyone know how?
Share this post
Link to post
designerstuart
it sounds like you are trying to edit a block? if so, use BEDIT to open block editor
otherwise autocad template files are just .dwg files saved as .dwt instead - you can select, open and save to these files just as dwg files.
Share this post
Link to post
JD Mather
File>Open *.dwt?
Can you attach the file here?
Why did you start a new thread for question you just asked in another thread?
Share this post
Link to post
SLW210
Post an example please.
Maybe you have a block inserted as a block? Try opening in the block editor and see what you have.
I have combined your 2 threads.
Please only post the same question once.
Share this post
Link to post
