Scale Issue w/ Multiple X-Refs
Something has happened int he last few days and I am not sure how to resolve it.
Anytime I have multiple X-ref's to a page (which is pretty much any drawing I do), I set the scale to one x-ref and then when I double click into the other x-ref the last x-ref I just scaled ends up jumping out of scale again.
The only way I can resolve it is to lock the viewport so it stays the right scale. Not a hard fix but AutoCAD should not be doing this. Anyone know what it might be?
Edit - I should add that any time I scale an xref and then leave that x-ref, when I double click to go into that view port again it just zooms all and loses it's scale unless I have locked the view port.
Sounds like the UCSFOLLOW variable needs to be set to 0. Do that inside a viewport, and maybe while in model layout.
Oh! I did change the UCSFollow recently so the views rotate when I want to work at an angle. That will do the trick I bet!
Thanks!
