Tolerance Settings
I am offsetting a line say 5000mm (5 meters) and when I put annotations like dimensions to it, I am getting 5000.168. Any settings for tolerance that has to be adjusted? I am using acad v2011.
Please help.
attach file here that exhibits this behavior
how far from 0,0,0 are you working?
Hi JD,
I'm not sure how far I am from 0, 0 origin but I know it's way off. The file I am working on is in the office, sorry can't send you anything now.
You might want to inspect if your geometry is parallel/perpendicular to the UCS. Adjust your decimal precision to 8, list the line and examine the start and end points of the object. Is your UCS icon on?
