Will9325
angled ortho - simple?
Will9325
This seems like a simple setting but I can not find it. I am working on a drawing that has been created by another firm. Due to the building not having the normal 0/90 walls they have rotated the orthographic projection to a 15 degree angle. When I try and draw a straight line in the "straight" part of the building with my ortho on, it pulls the aperture to 15 degrees. Yes, I could turn my ortho off but would prefer to toggle the angle between 15 degrees and 0/180 degrees. What is the setting to change it and how do I get there?
Share this post
Link to post
rkent
Probably the ucs has been rotated, use the ucs command, save option first, give it a name, then use the ucs world option.
Share this post
Link to post
Will9325
nope checked that. It is set to world
Share this post
Link to post
eldon
Perhaps the SNAPANG has been set to align with the building :unsure:
Share this post
Link to post
alanjt
Check SNAPANG and make sure view is set to TOP.
Share this post
Link to post
Will9325
Yep! Snapang was set to 45 degrees! man, I feel like a dumb arse. Thanks for the help. It has baffled me for a few hours.
You da man alan!
Thank you,
Will9325
Share this post
Link to post
