KE1 Posted November 11, 2011 Share Posted November 11, 2011 I don't have AutoCad, but I was given a DWG that was created in 2007. It is a map of a lake's water depth vs distance in the east and north directions. Is it possible extract the actual value of water depth from the DWG file? For example the file would contain columns of x-location, y-location, and water depth. Quote Link to comment Share on other sites More sharing options...
KJB Posted November 11, 2011 Share Posted November 11, 2011 Extracted? Doubt it. But there area free AutoCAD viewers. Quote Link to comment Share on other sites More sharing options...
KE1 Posted November 11, 2011 Author Share Posted November 11, 2011 I was able to use a free viewer, CAD2Shape to extract a xyz file from the DWG file. However the xyz information was only the easting/northing location of the depth contours. I could not seem to get to the point-by-point measurements of easting, northing, water depth that went into a shaded color plot of the bathymetry that the DWG file contains. Quote Link to comment Share on other sites More sharing options...
Tankman Posted November 12, 2011 Share Posted November 12, 2011 Extracted? Doubt it. But there area free AutoCAD viewers. With AutoDesk's True View, you can manually read dimensions from *.dwg and/or *.dxf drawings. Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted November 12, 2011 Share Posted November 12, 2011 AutoCAD Drawing Viewer 2.0 Copyright © 2009 SkySof Software Inc. All Rights Reserved AutoCAD Drawing Viewer is a powerful utility for AutoCAD DWG and DXF files. Features include: View and open drawings, find and replace block attribute values, find and replace text values, turn layers on/off, set layer color, delete block attribute objects and text objects, print drawings, copy drawing to ClipBoard, save drawing as a BMP file, etc. AutoCAD Drawing Viewer does not require AutoCAD to run and is compatible with all AutoCAD drawing versions. http://www.skysof.com/ Quote Link to comment Share on other sites More sharing options...
Grant Posted November 14, 2011 Share Posted November 14, 2011 Could try DRAFTSIGHT - this is very much like Autocad Lite but for free Quote Link to comment Share on other sites More sharing options...
KE1 Posted November 14, 2011 Author Share Posted November 14, 2011 Thanks for all the suggested software! Unfortunately I think the person who made the *.dwg file did a colorplot of [northing, easting, water depth] in another software package to make a color plot, so I won't be able to access the depth info. Quote Link to comment Share on other sites More sharing options...
audiocontr Posted November 14, 2011 Share Posted November 14, 2011 A dxf created in autocad 2007 (or lower) should not have true lat/lon coordinate information. Instead its based of off a 0,0 space. you would need to georectify the dxf by use of two control points or a georectified image. Quote Link to comment Share on other sites More sharing options...
