zantaff Posted November 12, 2011 Share Posted November 12, 2011 I'm a college Architecture student using CAD 2011 for MAC. I have multiple copies of a block, and when I move one copy to a layer, it doesn't seem to actually move. For example, if I have 2 copies of block A, and move one copy from layer "Inside" to layer "Outside", then hide layer "Outside", the block I just moved doesn't hide, but everything else on layer "Outside" does hide. When I inspect the moved block, the properties say it's on layer "Outside". What is going on? Thanks! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted November 12, 2011 Share Posted November 12, 2011 The entities in the block are on a different layer. Quote Link to comment Share on other sites More sharing options...
danellis Posted November 12, 2011 Share Posted November 12, 2011 There are two ways to deal with the layering of objects within blocks.. Anything on Layer 0 will take on the properties of the layer the block's inserted on (linetype, colour, etc.). Anything put on a specific layer will keep the properties of that layer. Which of these two methods you use (they can, of course, be used in combination) will vary based on how you expect to use the block. dJE Quote Link to comment Share on other sites More sharing options...
Bogbadbob658 Posted November 12, 2011 Share Posted November 12, 2011 Note - If you have the objects within the block on different layers and then you 'freeze' the layer the block is on rather than turn it 'off' the objects within the block will disappear. Therefore in your original question if you were to use 'freeze' your block should disappear. Quote Link to comment Share on other sites More sharing options...
