nicnicman Posted October 19, 2008 Posted October 19, 2008 Is there a way to undo the REVOLVE command? Thanks Quote
nocturne00 Posted October 20, 2008 Posted October 20, 2008 Doesnt UNDO command work for you if ever you made an error? Quote
Cad64 Posted October 20, 2008 Posted October 20, 2008 If you Revolve a profile and then Save and Close your drawing, there is no way to Undo what you did. I always save copies of my profiles, off to the side, in case I need to fix something or make an adjustment later. That way I don't have to recreate them. You might also want to have a look at THIS thread. Quote
fuccaro Posted October 20, 2008 Posted October 20, 2008 If you can't get back to the revolved profile, section the resulted solid with a plane containing the rotation axis. After some editing you can have the profile. Quote
shift1313 Posted October 27, 2008 Posted October 27, 2008 i think if you take a section of the part you will keep the solid and get a slice of the part. might get you close. Quote
