Variable in DXF code
dirkvandonkelaar
Hi all,
I have a problem with my list, according to the code below.
   (if (null (tblsearch "style" teksthoogte))
     (entmake
       (list
         '(0 . "STYLE")
  '(-3                                     ;; Make the style annotative
           ("AcadAnnotative"
             (1000 . "AnnotativeData")
             (1002 . "{")
             (1070 . 1)
             (1070 . 1)
             (1002 . "}")
         '(100 . "AcDbSymbolTableRecord")
         '(100 . "AcDbTextStyleTableRecord")
         '(2 . teksthoogte)                       ;; Style name
         '(70 . 0)                                ;; Standard flag values (bit-coded values)
         '(40 . 1.                              ;; text height
         '(41 . 1.0)                              ;; width factor
         '(50 . 0.0)                              ;; oblique angle
         '(71 . 0)                                ;; text generation "0" normal text
         '(42 . 0)                                ;; last height used
         '(3 . "Arial.ttf")                       ;; font file name
         '(4 . "")                                ;; bigfont (blank for no)
       )                                          ;; end list
     )                                            ;; end entmake
   )                                              ;; end if
When I run this LISP, AutoCAD says:
; error: bad DXF group: (2 . TEKSTHOOGTE)
So, my question is: how can i get the variable "teksthoogte" working in this list?
That's not the solution, when you wrap quotes arrount it, AutoCAD sees it as text, while it needs to be an variable which is set earlier in the LISP.
Why not?
See if this works (possible problems is non-english letters,
if I remember that right, I have a got same problem once with
german "A" umlaut letter)
Copy paste this snip:
(setq teksthoogte "ANNO-Tekst 2.5")
(if (not (tblsearch "style" teksthoogte))
     (entmake
       (list
         '(0 . "STYLE")
           ("AcadAnnotative"
             (1002 . "{")
             (1070 . 1)
             (1070 . 1)
             (1002 . "}")
         (cons 2  teksthoogte)                       ;; Style name
       )                                          ;; end list
     )                                            ;; end entmake
   )                                              ;; end if
Hi all,
Thanks for the replies.
Lee Mac, your thread did not really helped me understanding (maybe 'cause my English is not great).
BUT, i've found a solution for my problem.
This is my code now:
     (entmake
       (list
         '(0 . "STYLE")
           ("AcadAnnotative"
             (1002 . "{")
             (1070 . 1)
             (1070 . 1)
             (1002 . "}")
         '(2 . (strcat teksthoogte))              ;; Style name
       )                                          ;; end list
     )                                            ;; end entmake
   )                                              ;; end if
The one thing i did was just replace
'(2 . teksthoogte)
with
Now, i just wanted to know if it's the right wat to do this.
'(2 . teksthoogte)
with
The strcat expression will not be evaluated (although strcat is no actually required) since the list is quoted and hence not evaluated (as explained in my thread).
Instead, use:
