Exported .dwg from sketchup has square edges on round surfaces
Bitseeder
Hi guys,
Having a issue with my .DWG imports from SketchUp PRO 8.
When i open them in AutoCAD 2012, all the round/curved faces are segmented and makes my annotation sheets look crap.
Have tried exporting my Sketchup model as a .FBX and a .3DS model, importing into Autocad, exploding the mesh, regioning the resulting 3dfaces then using SURFSCULPT to create a solid.
would Really love to know how to make these surfaces smooth.
attached is a PDF to show you what im talking about.
Any help would be greatly appreciated.
:oops:
Edited by Cad64
Language
The problem is that SU really does not do curved surfaces. It just simulates them. Don't get me wrong I love SU but that assembly looks like it could be done in Acad just as easily and with true curved surfaces.
thanks mate,
I use SU for my 3d for the speed i can do these types of things. I do use AutoCAD for more crucial components, But a pipe run with multiple axis and angles just eats up to much time.
what i have done though is configure SU circle to draw 100 edges instead of the 24 that was in the previous pdf. not perfect but does look a lot better
Untitled-Layout1.pdf
That does look better. What did you render that in? I like SU for it's speed as well. When I do cuvred items I usually smooth out the curved items or hide the lines.
Thanks for sharing and welcome to CADTutor :)
  • 2 weeks later...
