easy question about navis z coordinate
blackeagle1245
I'm very new to navisworks. I export my mep drawings to navisworks and now I can walk with third person. But how can I put him to zero coordinate of Z axe?. I can move by pan but dont know exactly how can I make Z coordinate constant?. And just wonder how tall is the third person ? :)
Do you have gravity turned on? If you do, his gravity will hold him in place, or rather keep him from floating away. If you put him on a deck or other flat surface, if you pass the edge he will fall off. Do you have crouch and collision turned on? I haven't used it much, nor in some time, but as I recall you can also adjust the height of the avatar.
