inserting a JPEG into my autoCAD LT drawing, and PDF it
matt lyons
Hi,
I am using AutoCAD LT 2009, and am having some problems.
I want to have some jpeg images on my cad drawing, so i just insert the image, which is fine. I can print this fine, and allis good. however,when i go to PDF the drawings, using a standard downloadable DWG - PDF convertor, the jpegs dissapear. everything else is fine, but the jpegs are no longer on the PDF'ed drawing.
can anyone help?
thanks,
Matt
Edited by matt lyons
VCB
Which converter are you using? Doesn't AutoCAD LT 2009 have a DWG to PDF.pc3?
i am using just something i downloaded - got it here http://anydwg.com/
maybe AutoCAD LT 2009 does have a DWG to PDF convertor - if so, then i dont know how to use it!!!! maybe you can tellme how i can convert the drawings to PDF without the convertor??
When selecting a plotter/printer in the plot dialog box choose the DWG to PDF.pc3.
yap, your dead right!!! thanks a million - all pdf'd now!!
thanks again.
Matt
