alijahed Posted February 3, 2012 Posted February 3, 2012 Hi All, I want to drive an angular constraint. But, instead one part moves towards the other I want to have the motion of both moving towards each other at the same time. Is it possible? Cheers Ali Quote
alijahed Posted February 3, 2012 Author Posted February 3, 2012 It sounds crazy but how can I attach files here! There is one for Image another one for video but there is noting for attaching other files! Quote
SLW210 Posted February 3, 2012 Posted February 3, 2012 Select "Go Advanced" at lower right of reply box, then "Manage Attachments". Should be a nice selection. Quote
alijahed Posted February 3, 2012 Author Posted February 3, 2012 Assembly1.zip Thanks, please see the attached file. Quote
JD Mather Posted February 3, 2012 Posted February 3, 2012 Can you assemble with a workplane in the middle of the desired motion and then name the variable parameter for the angle constraint and then drive the parameter? Quote
