Power units (Watts) in Cell on table
Dear All,
I have been made one load schedule for distribution panel by using table command in autocad.
In that table, I have to mention load with units(watts) for each circuit in cell. (example: 6000w).
If I put like 6000w in a cell, the sum formula's is not working. These formula's used to get total load of panel.
what should i do to rectify this problem?
how to mention this units in a cell?
thanks in advance.
If I understand you correctly, you are trying to add non-numerical strings. Can you make an extra cell for just the letter "w"? Then you can have a cell with the "number" 6000, and an adjacent cell with the "letter" w.
Perhaps you could put the unit in the column header similar to this: LOAD (Watts)?
