Denpac Posted February 15, 2012 Share Posted February 15, 2012 When I highlight any object in model space the layer control, color control or line type control does not change from the current layer status to the layer of the high lighted object if it is different. I am also not able through this layer control bar able to high light an object and use the fly out arrow to go into the layers and change this object to another desired layer for this object. I have never seen this function just not work before and can find no setting or preference that might not be turned on to make it function. Does anybody have any ideas to why it is not functioning? Quote Link to comment Share on other sites More sharing options...
MSasu Posted February 15, 2012 Share Posted February 15, 2012 Please check that PICKFIRST system variable is set to 1. Regards, Mircea Quote Link to comment Share on other sites More sharing options...
Denpac Posted February 15, 2012 Author Share Posted February 15, 2012 You are Awesome, Thanks! Quote Link to comment Share on other sites More sharing options...
MSasu Posted February 15, 2012 Share Posted February 15, 2012 You are Welcome! I have never seen this function just not work before and can find no setting or preference that might not be turned on to make it function. This is also accessible from Options -> Selection -> Selection modes -> Noun/verb selection; it is intended to resemble functionality of very old AutoCAD releases. Regards, Mircea Quote Link to comment Share on other sites More sharing options...
