hendersondayton Posted October 23, 2008 Share Posted October 23, 2008 I have been succesful in editing the VALUE of an attribute using VBA using the following Code: On Error Resume Next With ThisDrawing For Each oLayout In .Layouts For k = 0 To oLayout.Block.Count - 1 Set entry = oLayout.Block.item(k) Objname = entry.ObjectName If Objname = "AcDbBlockReference" Then If entry.Name Like "Title Info*" Then atts = entry.GetAttributes For I = LBound(atts) To UBound(atts) If atts(I).TagString = "PG" Then atts(I).TextString = oLayout.Name End If I am now trying to edit this specific attributes WIDTH FACTOR and I am having a hard time doing so. Any suggestions would be great Quote Link to comment Share on other sites More sharing options...
fixo Posted October 23, 2008 Share Posted October 23, 2008 Welcome on board! Give that a try Private Sub Ch_Att_Width(bName As String, atag As String, dblWid As Double) Dim oSset As AcadSelectionSet, _ blkRef As AcadBlockReference, _ attObj As AcadAttributeReference, _ attData() As AcadObject, _ fType(2) As Integer, _ fData(2) As Variant, _ dxfType, _ dxfData, _ k As Integer fType(0) = 0: fType(1) = 2: fType(2) = 66 fData(0) = "INSERT": fData(1) = bName: fData(2) = 1 dxfType = fType: dxfData = fData For Each oSset In ThisDrawing.SelectionSets If oSset.Name = "$Blocks$" Then oSset.Delete Exit For End If Next oSset Set oSset = ThisDrawing.SelectionSets.Add("$Blocks$") MsgBox "Select blocks on screen" oSset.SelectOnScreen dxfType, dxfData For Each blkRef In oSset attData = blkRef.GetAttributes For k = 0 To UBound(attData) Set attObj = attData(k) If StrComp(attObj.TagString, atag) = 0 Then attObj.ScaleFactor = dblWid attObj.Update blkRef.Update Exit For End If Next k Next blkRef oSset.Delete Set oSset = Nothing MsgBox "Done" End Sub Sub demo() Ch_Block_Att_Width "MLR", "PRESET", 0.45 ' where: "MLR" is block name, ' "PRESET" is desired tag, ' 0.45 is width factor End Sub ~'J'~ Quote Link to comment Share on other sites More sharing options...
russell84 Posted October 24, 2008 Share Posted October 24, 2008 Anotherway SUB rename&changewidth() Dim j, k As Integer Dim ELEMENT, ArrayAttributes On Error Resume Next For j = 0 To ThisDrawing.Layouts.Count - 1 If ThisDrawing.Layouts(j).Name = "Model" Then GoTo 10 ThisDrawing.SendCommand "layout s " & ThisDrawing.Layouts(j).Name & vbCr For Each ELEMENT In ThisDrawing.PaperSpace If ELEMENT.EntityType = 7 Then If Err Then GoTo 5 If ELEMENT.HasAttributes = True Then ArrayAttributes = ELEMENT.GetAttributes For k = LBound(ArrayAttributes) To UBound(ArrayAttributes) If ArrayAttributes(k).TagString = "[color=red]TYPEATTRIBUTETAGLABELHERE[/color]" Then ArrayAttributes(k).TextString = "[color=red]TYPE TEXT TO CHANGE ATTRIBUTE TO HERE[/color]" If ArrayAttributes(k).TagString = "[color=red]TYPEATTRIBUTETAGLABELHERE[/color]" Then ArrayAttributes(k).ScaleFactor = [color=red]12[/color] ' this is the width of your attribute Next k End If 5 End If Next 10 Next j End SUB Quote Link to comment Share on other sites More sharing options...
