Ascii and (vl-string-elt) give wrong answers!!
grandhougday
Look I am not saying that Lee's function isn't good... It's working - I've checked it with list '(92 85 43 48 48 68 69) and (_ascii lst) gave result 222... I am just saying that on both my comps. (netbook with A2008 ) and (PC with A2012), when typed at command line : (vl-string->list "Þ") the result was (222), so I am guessing something's wrong with your CAD, or I am guessing wrong, I should get (92 85 43 48 48 68 69) as result???
M.R.:?
  • Replies 27
  • Lee Mac
    11
  • grandhougday
    9
  • Ahankhah
    5
  • marko_ribar
    3
Are you sure you are testing it correctly?
For me:
_$ (ascii "Þ")
222
This is the result:
Command: (vl-string->list "Þ")
This is some sort of wrong result - on my comp it's correct :
(222)
M.R.:)
what is your Dwgcodepage?
(getvar 'Dwgcodepage)
Lee,
let me edit your excellent code so the internal "ascii" function can be replaced with the new one:
Thank you Ahankhah :)
I might be inclined to code it in this way to save some unnecessary calls:
(defun _ascii ( ch / ls )
   (if (setq ls (cdddr (vl-string->list ch)))
       (_HexList->Decimal (reverse ls))
       (ascii ch)
(defun _HexList->Decimal ( lst )
   (if lst
       (+  (* 16 (_HexList->Decimal (cdr lst)))
           (if (< (car lst) 65)
               (- (car lst) 48)
               (- (car lst) 55)
       0
Though, both are equally valid :)
Command: (getvar 'Dwgcodepage)
"ANSI_1252"
M.R.
Your codepage is English, so the reply is correct.
Mine is Arabic ("ANSI_1256"), so I guess the reason for different behavior of AutoCAD is not due to a bug.
Mine is Arabis ("ANSI_1256"), so I guess the reason for different behavior of AutoCAD is not due to a bug.
Exactly, Windows-1252 includes the Extended ASCII set (128-255), Windows-1256 (and most other code pages) does not - hence such characters are rendered as Unicode code-points)
