Trouble making a PDF
Please take a look at this sample drawing for me its fine to view in autocad, but most of the sockets etc are what i called washed out and in a very light grey colour, now if i try to make a PDF of this drawing they will not show up in the pdf they just disappear, can anyone explain why this is as no matter what i try i cant figure it out at all, I wont be back in the office until Monday so forgive me if i dont say thanks right away
sample.dwg
Link to post
Typically, we don't all use newer versions of AutoCAD.
When working, I always save as vs. 2000 by request.
We users, 2007, 2005, 2000, can't open drawing *.dwg files saved in the newer, '08 - '09 versions.
Might be a good idea to post *.dwg files in vs. 2000?
Link to post
Does setting to monochrome work, I have had this issue before and this did fix as other poster mentioned. If its not this then its that you likely have pen widths set way to thin but I would try monochrome first. See attachment
cadmono.pdf
Link to post
Thanks everyone yes using the monochrome ctb. did correct the problem, as I only ever modify drawings can I ask one more question about this ?, Is it possible to change the parts that don't print pen widths, within a drawing once they are set up ?
BTW sry Tankman I wasnt aware that you cant open DWG in older cad versions I will try to remember next time
Link to post
Actually, you can open newer versions of AutoCAD using "DWG gateway".
I'm new to CAD myself, so I'm not sure if it was a special download or not (the computer I'm using was someone else's who knew much more about what they were doing than I). It was on my top menu bar when I aquired this computer.
I was able to open sparkyuk's file with my OLD AutoCAD 2000 Version, and I have been able to open other files sent to me from clients, etc. I've never tried to save them in newer versions, but a button to do so is also part of the "DWG gateway".
I hope this helps someone. Many of you have been much help to me. =)
Link to post
