Moving Text Block to adjacent point
archipelag0
I would suggest a different way ssget points, then use ssget "F" "insert" this finds the closest insert to the point as the "fence" can be tuned in terms of size. Then just change Z of Insertionpoint. Very short code.
Similar problem
Edited by BIGAL
  • 6 months later...
Hello,
This is really helpful. However, I have the problem that some of the text is aligned and rotated and the lisp uses its Alignment coordinates (Text alignment X and Text alignment Y) as the basepoint to move it to the point. Is there a way to use the text Position (Position X and Posiotion Y) coordinates instead?
Hi Lee
The txt2pnt lisp, I was wondering if a max search radius could be added, so after a predefined distance the lisp would then give up trying to find a match for that point and move on.
Its agreat lisp when every point has corresponding text, but no when the data doesn't conform.
It would be a great additon to an already useful lisp.
Many thanks
Pads
Here's a quick modification -
;; Text 2 Point  -  Lee Mac 2012
;; Prompts for a selection of Text and Point entities and moves
;; each Text entity to the nearest (2D distance) Point entity in the set.
;; Retains existing Text elevation.
(defun c:txt2pt ( / _textinsertion di1 di2 dxf ent inc ins lst mpt mrd pnt sel txt )
    (setq mrd 10.0) ;; Maximum permissible distance
   (defun _textinsertion ( elist )
       (if
           (and
               (zerop (cdr (assoc 72 elist)))
               (zerop (cdr (assoc 73 elist)))
           (cdr (assoc 10 elist))
           (cdr (assoc 11 elist))
   (if (setq sel (ssget "_:L" '((0 . "POINT,TEXT"))))
           (repeat (setq inc (sslength sel))
               (setq ent (entget (ssname sel (setq inc (1- inc)))))
               (if (eq "POINT" (cdr (assoc 0 ent)))
                   (setq lst (cons (cdr (assoc 10 ent)) lst))
                   (setq txt (cons (cons (_textinsertion ent) ent) txt))
           (foreach ent txt
               (setq ins (list (caar ent) (cadar ent)))
               (if (setq pnt (vl-some '(lambda ( pnt ) (equal ins (list (car pnt) (cadr pnt)) 1e-8)) lst))
                   (setq lst (vl-remove pnt lst))
                       (setq di1 (distance ins (list (caar lst) (cadar lst)))
                             mpt (car lst)
                       (foreach pnt (cdr lst)
                           (if (< (setq di2 (distance ins (list (car pnt) (cadr pnt)))) di1)
                               (setq di1 di2
                                     mpt pnt
                       (if (< di1 mrd)
                               (setq pnt (list (car mpt) (cadr mpt) (caddar ent))
                                     dxf (cdr ent)
                                     dxf (subst (cons 10 pnt) (assoc 10 dxf) dxf)
                                     dxf (subst (cons 11 pnt) (assoc 11 dxf) dxf)
                               (entmod dxf)
                               (setq lst (vl-remove mpt lst))
(vl-load-com) (princ)
  • 10 months later...
Someone asked me for a modified version so I'm posting it here with thanks to Lee Mac.
  • prompts for maximum movement distance
  • allows MTEXT and Civil 3D Cogo Points
  • only modifies group code 10 or 11, not both
(defun c:txt2pt ( / _textinsertion _pointinsertion di1 di2 dxf dcd ent entname inc ins lst mpt mrd pnt sel txt )
       (if
           (or (= "MTEXT" (cdr (assoc 0 elist)))
               (and
           (assoc 10 elist)
           (assoc 11 elist)
   (defun _pointinsertion ( ename elist / vp res )
       (if (= "AECC_COGO_POINT" (cdr (assoc 0 elist)))
         (setq vp  (vlax-ename->vla-object ename)
               res (list (vlax-get-property vp 'Easting)
                         (vlax-get-property vp 'Northing)
                         (vlax-get-property vp 'Elevation)))
         (setq res (cdr (assoc 10 elist)))))
   (setq mrd
       (cond
           ((getreal (strcat "\nMaximum move distance <" (rtos mrd 2 1) ">: ")))
           (mrd)
   (princ "\nSelect point and text objects...\n")
   (if (setq sel (ssget "_:L" '((0 . "POINT,TEXT,AECC_COGO_POINT,MTEXT"))))
               (setq ent (entget (setq entname (ssname sel (setq inc (1- inc))))))
               (if (or
                       (eq "AECC_COGO_POINT" (cdr (assoc 0 ent)))
                   (setq lst (cons (_pointinsertion entname ent) lst))
           (foreach ent txt
               (setq ins (list (cadar ent) (caddar ent)))
                             mpt (car lst)
                               (setq di1 di2
                                     mpt pnt
                       (if (< di1 mrd)
                                     dcd (caar ent)
                                     dxf (cdr ent)
                                     dxf (subst (cons dcd pnt) (assoc dcd dxf) dxf)
                               (entmod dxf)
  • 1 year later...
       (if
           (and
           (foreach ent txt
                             mpt (car lst)
                               (setq di1 di2
                                     mpt pnt
                       (if (< di1 mrd)
                                     dxf (cdr ent)
                               (entmod dxf)
Hi, Lee
I am trying to achieve the same thing but I need to also move the blocks to the points
Do you have a lsp routine that do this by any chance?
Thank you.
  • 1 month later...
Another mod of the original code from Lee Mac (Thanks).
Comments in the header.
;; https://www.cadtutor.net/forum/topic/37515-moving-text-block-to-adjacent-point/?do=findComment&comment=566551
;; MODIFICATIONS BY 3DWANNAB
;; Modified on 2022.11.18 by 3dwannab.
;;  - Added INSERT along with POINT to the selection.
;;  - Added undo handling.
;;  - Prompt to pick fuzz value.
;;  - Retain slection after the command.
;; Modified on 2022.12.09 by 3dwannab.
;;  - Added MTEXT to program.
;; Credit to Lee Mac for the original coede
(defun c:Text_2_Point_Or_Block (/ *error* acDoc _textinsertion dcd di1 di2 dxf ent entname inc ins lst pnt regFuzz sel txt)
  (defun *error* (errmsg)
    (and acDoc (vla-EndUndoMark acDoc))
    (and errmsg
         (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*"))
         (princ (strcat "\n<< Error: " errmsg " >>\n"))
  (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc))
  ;; Get saved value from the registry or default to 1
  (setq regFuzz (read (cond ((getenv "Text_2_Point_Or_Block_Fuzz_Value")) (1))))
  (setq regFuzz (cond
                  ((getdist
                     (strcat "\nPick or enter the gap tolerance to move the TEXT to POINTS or BLOCKS :\nCurrent value <"
                             (vl-princ-to-string (getenv "Text_2_Point_Or_Block_Fuzz_Value"))
                  (regFuzz)
  ;; Set the registry value to the variable
  (setenv "Text_2_Point_Or_Block_Fuzz_Value" (vl-princ-to-string regFuzz))
  (defun _textinsertion (elist)
    (if
          (and
      (assoc 10 elist)
      (assoc 11 elist)
  (if (setq sel (ssget "_:L" '((0 . "POINT,INSERT,TEXT,MTEXT"))))
        (if
          (or
            (eq "INSERT" (cdr (assoc 0 ent)))
      (foreach ent txt
        (if (setq pnt (vl-some '(lambda (pnt) (equal ins (list (car pnt) (cadr pnt)) 1e-8)) lst))
                  mpt (car lst)
                (setq di1 di2
                      mpt pnt
            (if (< di1 regFuzz)
                      dcd (caar ent)
                      dxf (cdr ent)
                (entmod dxf)
  (sssetfirst nil sel)
  (command "_.REGEN")
  (*error* nil)
(vl-load-com)
; (c:Text_2_Point_Or_Block) ;; Use for testing only
  • 2 months later...
    (and errmsg
  (setq regFuzz (cond
                  ((getdist
                  (regFuzz)
    (if
          (and
      (assoc 10 elist)
      (assoc 11 elist)
        (if
          (or
      (foreach ent txt
                  mpt (car lst)
                (setq di1 di2
                      mpt pnt
            (if (< di1 regFuzz)
                      dcd (caar ent)
                      dxf (cdr ent)
                (entmod dxf)
  (command "_.REGEN")
  (*error* nil)
(vl-load-com)
i try to run this lisp but it´is appear an error message:  << Error: bad argument type: stringp 1 >>, can you help me please
  • 1 month later...
@aarong85 try this. I sometimes struggle with writing and reading to and from the registry.
;; Link https://www.cadtutor.net/forum/topic/37515-moving-text-block-to-adjacent-point/?do=findComment&comment=605448
;; Modified on 2023.03.30 by 3dwannab.
    (and errmsg
  ; (setq regFuzz (read (cond ((getenv "Text_2_Point_Or_Block_Fuzz_Value")) (1))))
  (setq regFuzz (cond ((getenv "Text_2_Point_Or_Block_Fuzz_Value")) (1)))
  (setq regFuzz (cond
                  ((getdist
                  (regFuzz)
    (if
          (and
      (assoc 10 elist)
      (assoc 11 elist)
  (if (setq sel (ssget "_:L" '((0 . "POINT,INSERT,TEXT,MTEXT,CIRCLE"))))
        (if
          (or
            (eq "CIRCLE" (cdr (assoc 0 ent)))
      (foreach ent txt
                  mpt (car lst)
                (setq di1 di2
                      mpt pnt
            (if (< di1 (read regFuzz))
                      dcd (caar ent)
                      dxf (cdr ent)
                (entmod dxf)
  (command "_.REGEN")
  (*error* nil)
(vl-load-com)
;;(c:Text_2_Point_Or_Block) ;; Use for testing only
Edited by 3dwannab
  • Thanks 1
  • 2 months later...
Text 2 point is a brilliant lisp that I use on a regular basis; would it be possible to add to the routine so the moved text colour would change to green and rotate to 0?
Hi Tony,
Which code are you using? My original code from this post?
6 hours ago, Tony M said:
Many thanks for replying and for creating this lisp, it has been really useful over the last few years!
Your original one I thinktxt2pt.lsp
I'm delighted to hear that you find the program useful after all these years!
Here's a tweak to rotate the text to 0 degrees and change the colour to green:
(defun c:txt2pt ( / _textinsertion di1 di2 dxf ent inc ins lst mpt pnt sel txt )
        (if
            (and
            (foreach ent txt
                              mpt (car lst)
                                (setq di1 di2
                                      mpt pnt
                              dxf (cdr ent)
                              dxf (subst '(50 . 0.0)    (assoc 50 dxf) dxf)
                              dxf (if (assoc 62 dxf) (subst '(62 . 3) (assoc 62 dxf) dxf) (append dxf '((62 . 3))))
                        (entmod dxf)
On 6/30/2023 at 12:45 PM, Lee Mac said:
You're welcome Tony, glad to help.
Heey @Lee Mac,
First of all i am really a big fan of yours, you really help so much with your genius lisp solutions. I wish you always success.
I am wondering if your lisp can move texts and lines too, here is the case
Sample.dwg
Edited by asdfgh
If you look into the command in VL lisp getclosestpointto that is the answer for this problem, just select the 3 objects, point, line & text. then based on the Line get the new point and move the text and object to the respective point.
The line with 10 may end up with the point on top of the 10.
Bit busy at moment will add to To do but some one else may jump in.
Edited by BIGAL
