rwsice9 Posted March 19, 2012 Share Posted March 19, 2012 We have 2 machines running Windows 7 64bit, and AutoCAD 2012. We use sheet sets extensively. When inserting a "sheet list table", which we use as our drawing index, it takes anywhere from 5-20 minutes on our Win7 machines, but takes only 2-3 seconds on our WinXP machines. Has anyone else run into this issue? Have any ideas of how to fix it? I've been emailing back and forth with Autodesk support, but we don't seem to be getting any closer to a resolution. Any ideas would be appreciated! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 19, 2012 Share Posted March 19, 2012 Are the XP machines 64 bit also? Quote Link to comment Share on other sites More sharing options...
rwsice9 Posted March 19, 2012 Author Share Posted March 19, 2012 Nope they are all 32 bit. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 19, 2012 Share Posted March 19, 2012 Update 1 loaded? Could it be a "pathing" problem? Quote Link to comment Share on other sites More sharing options...
rwsice9 Posted March 19, 2012 Author Share Posted March 19, 2012 Yep, SP1 is loaded, as well as the latest hotfix (which was supposed to actually fix the issue). Not quite sure what you mean by a "pathing" problem. All I know is I get the same performance whether I have the drawings stored on a server or a local drive. Slow either way.. Quote Link to comment Share on other sites More sharing options...
