T704 Posted March 20, 2012 Share Posted March 20, 2012 working with Land Desk Top 2002, need to export boundary lines to KML for use in Google Earth, found a .shp converter to kml (is is not working I don't believe it is picking up the coordinates to place correctly in G-Earth). was hoping any of you may be able to help. Quote Link to comment Share on other sites More sharing options...
sanrajbhar Posted March 21, 2012 Share Posted March 21, 2012 hello ! Just download Quantam GIS (Qgis,Open Source Software). make that object to shape file. Load that SHP into QGis and right click on layer to have save as option to KML. Hope this helps. Let me know if u face any problem in it. http://hub.qgis.org/projects/quantum-gis/wiki/Download Quote Link to comment Share on other sites More sharing options...
T704 Posted March 21, 2012 Author Share Posted March 21, 2012 Trying without success! There is a learning curve associated with qgis, looks promising (qgis) thanks for the information. Can you send me your contact information in my messages that you may be able to assist with a problem i may encounter? Thank you for your response! Quote Link to comment Share on other sites More sharing options...
sanrajbhar Posted March 22, 2012 Share Posted March 22, 2012 Trying without success! There is a learning curve associated with qgis, looks promising (qgis) thanks for the information. Can you send me your contact information in my messages that you may be able to assist with a problem i may encounter? Thank you for your response! Sure !, You can mail me if you face any problem to sanrajbhar@gmail.com. See Qgis is not dat much user friendly as GIS Product from ESRI. But it can use for some data manupulation. i myself also used when times comes such like dat. Qgis supports much of file format. Ok ! nw Gm called me to plot some bounday on map(it has local co-ordinate). And also to calculate locational co-ordinate (LAT/LONG) value of same... seems little difficult ..ok will help in free time... Quote Link to comment Share on other sites More sharing options...
