Jecobin Posted March 27, 2012 Posted March 27, 2012 Hi All, When I create a curve using spline on the screen I have noticed that often the curve between the points of the spline will become as straight lines. When I click on a point the curve appears again as normal and as I wanted. Could anyone tell me why this happens and if there is a way to stop it from happening? Is this simply a characteristic of AutoCAD or something I am doing wrong? Does the curve appear as desired when plotted? The curves I am referring to are sections of a ships hull. Regards, John Quote
addesigns Posted March 27, 2012 Posted March 27, 2012 It may just be because you are moving around alot in model space. RE command (Regen) is my best friend. I use it every 5 minutes or so, just to make sure I did miss anything im my drawings. Quote
JD Mather Posted March 27, 2012 Posted March 27, 2012 sounds like viewres should be set higher I use 2000 you can set as high as 20,000 Quote
