centering within drawing limits
darris07
my professor insists that i set drawing limits and center my drawing within the limits. he never quite explained how to do this and he wants me to find out on my own. how can this be done?
what are you drawing and what are your drawing limits?
are you able to find the center of your limits? you could draw a line from your min to your max limits and the center would be the midpoint of that line.
depending on what you are drawing, find the center of your drawing and move it to the center of the limits you found earlier.....
Turn Grid on. it shows the limits
or
type Limmin, it will return LL corner of Limits
Limmax will return UR corner
Draw a line from LL to UR, center your drawing at the midpoint
p.s. this will probably be the last time you ever use limits.
im drawing a set of floor plans and some elevations. he wants the floor plans centered in the left half of the drawings limits and the elevations in the right
draw a line dividing your limits in half.....move the floor plans to the middle of the side you want....do the same for the elevations
