Snap to the end of a mesh
ripgrif
I have moved a mesh off to the side while I work on the 3d solid substructure the mesh covers. Now I need to move the mesh back, but it will not select the end "corner" of the mesh so I can place it back into position. This was not a problem in the past (2008), but it doesn't work in our current version of AutoCad 2009. Is there a system variable or setting I need to set?
Thanks Paul,
No luck. It is really odd, I can select many of the interior intersections of the mesh, but I can usually only select one corner of the mesh. Unfortunately it isn't usually the corner I need to move/copy the mesh to its new location. This is the weirdest thing.
Thanks for the help.
