haseebsarwar42 Posted May 6, 2012 Posted May 6, 2012 hi, i have install autocad 2009 ,i want to know to add toolbads like 3d visual style etc but there is no option in autocad 2009 like autocad 2007 plz help:cry: haseeb Quote
Dadgad Posted May 6, 2012 Posted May 6, 2012 Right click in your COMMANDLINE > OPTIONS > PROFILES > AUTOCAD CLASSIC. Configure the OPTIONS on the tabs the way you like them, then save the new PROFILE you have created, so you can always easily access the settings you like. Once back in you layout you should probably set up a workspace configured with your favorite toolbars and SAVE it, and also select it as your HOME workspace in the workspace configuration dialog. I hope you remembered to install the EXPRESS TOOLS too. Quote
