Moving points from one file to another
bachrock
How do I move point from one file to another in Civil 3d? Copy/Paste won't work. I need to import them to the second drawing somehow. Thanks.
Copy/Paste have a history of not working in some cases. I don't think it has ever been fully resolved.
Possible workarounds: INSERT the dwg with the points in them as a block and then explode the block (if needed).
ATTACH the dwg with the points as a X-ref, bind it (if needed) and explode (if needed).
If it is just One POINT - note down the coordinates on a piece of paper and transfer it manually.
Copy/Paste works does work in that in copies the points, but I was told the pasted points will no longer contain as much data.
