Colour Fill a Box?
D1-Xen
Another noob question... :unsure:
How do we fill a rectangle or any close shape surface with a colour? Commands please?
Gave a search and there was not much on the keyword "fill".
Once hatch is activated, the menu that pops up will allow you to select the object (make sure its closed or the hatch wont work) then after its selected select from the drop down menu the solid option and select the colour you want press return and bobs your uncle it should be done ok ?
