Dr_Freeman
Changing object material
Dr_Freeman
With command massprop I can get many interesting data about 3d object, but where can I set material that my object is made of. Lets say I need to calculate volume and mass of my object which is made of aluminium, what are my options?
Share this post
Link to post
ReMark
You would probably have to use a combination of math (a formula) inside a lisp routine. Plain AutoCAD does not have the capability you are seeking.
Share this post
Link to post
Dr_Freeman
What is the default material used for calculating mass? If it has density 1 I could only multiply result with custom material density.
Share this post
Link to post
nestly
I'm pretty sure AutoCAD calculates mass based on a density of 1 (water)
Share this post
Link to post
