Hi
Using autocad LT 2008.
I am working in the constriction field. Usually I receive a drawing from the architect , than I need to create my version of his drawing , meaning I need to emphasis the important construction geometry.
AutoCAD speaking, im using the CTB file to control this color request
1. I set all 255 pans to gray (architect plane fade out)
2. I set random color to blue (emphasizing my geometry)
Is it the right way to achieve what I want?
Hi
Assuming your CTB is set to plot gray with a thin line and or gray scale and other colors to thicker line weights then yes that is how most do it using CTB.
