PElgin Posted June 27, 2012 Posted June 27, 2012 Odd problem here: In the perspective viewport, when I roll the mouse roller, one small click, the object snaps from being 60 ' away to being inside it. This just started this afternoon, I don't think I did anything to make that happen. I looked in viewport configuration but can't find anything to deal with this. Doesn't happen in the other viewports. How to fix? Thanks. Quote
Cad64 Posted June 27, 2012 Posted June 27, 2012 Click on an object to select it and then hit the little "Zoom Extents All Selected" button in the lower right corner. The mouse wheel should work better after you do this. If not, close Max and then start it back up again. Quote
PElgin Posted June 28, 2012 Author Posted June 28, 2012 I'll try that. I've been using the magnifying glass but it's a bit awkward. Strangely, sometimes the mouse magnification works properly but sometimes it's really screwy, as I discribed above. Thanks. Quote
