SAM_R Posted July 6, 2012 Posted July 6, 2012 If I overlay a PDF into a DWG is there a way I can use snaps to line up the PDF on my drawing? Quote
nestly Posted July 6, 2012 Posted July 6, 2012 I think it depends on how the PDF was created (Vector vs Raster) Quote
tzframpton Posted July 6, 2012 Posted July 6, 2012 I think it depends on how the PDF was created (Vector vs Raster)What nestly stated, and the PDFOSNAP variable as well.http://exchange.autodesk.com/autocad/enu/online-help/search#WS73099cc142f48755-1257e12111bf108800e3caf.htm Quote
SAM_R Posted July 6, 2012 Author Posted July 6, 2012 How can I check if there Vector or Raster made Quote
nestly Posted July 6, 2012 Posted July 6, 2012 Other than contacting the person that created the PDF, I don't know if there's a way to tell the difference before inserting it into your drawing. If you can Osnap to the endpoints of geometry, then it's a vector pdf. Even if it's not a vector PDF, you should still be able to move/rotate/scale it by "eyeballing" the features in the pdf to get it aligned with your drawing. Quote
