skotseno
Issue With Layers
skotseno
I am new to this but I need a lisp that would create the following layers with every (even pre existing) files that I open.
Layer: 1 in cyan, 2 in white, 2L in white, 3 in red, 4 in yellow, 5 in white, 6 in blue, SK1 in cyan, SK2 in white, SK3 in red, SK4 in yellow, and SK6 in blue.
I have looked at existing lisps and macros but I am new and am having trouble making sense of them.
Share this post
Link to post
MSasu
I think this will do the trick; please try to fill by yourself the remaining cases:
(foreach layerItem '([color=blue][color=red]("1" 4) [color=orange]("2" 7)[/color][/color] ("2L" 7)[/color])
(entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord")
               (cons 2 (car layerItem)) '(70 . 0) (cons 62 (cadr layerItem)) '(6 . "Continuous")))
Share this post
Link to post
BlackBox
Why not simply make these layers part of your template? :unsure:
Building on Mircea's post, here's a Visual LISP adaptation:
((lambda (oLayers / layerName)
  (foreach layerItem '(("1" 4) ("2" 7) ("2L" 7))
   (vla-put-color
     (apply
       (if (tblsearch "layer" (setq layerName (car layerItem)))
        'vla-item
        'vla-add
       (list oLayers layerName)
     (cadr layerItem)
 (vla-get-layers
   (vla-get-activedocument (vlax-get-acad-object))
Share this post
Link to post
MSasu
That was my first thought also, but next notified that OP was looking to have that layer structure created on existing drawings too.
Share this post
Link to post
BIGAL
Old fashioned script will do also just open in notepad add layers change etc
-la
n layer1 C layer1 1
n layer2 C layer2 2
n layer3 C layer3 3
Share this post
Link to post
skotseno
Thanks Lee Mac! I tried posting this code into acaddoc but nothing happens. please advise.
(defun _layer3 ( name color linetype lineweight plot )
(if (null (tblsearch "LAYER" name))
(entmake
(list
'(0 . "LAYER")
'(70 . 0)
(cons 1 name)
(cons 6 linetype)
(cons 4 colour)
(cons 290 plot)
(cons 15 lineweight)
(_layer3 "2" 7 "Continuous" 15 1)
(_layer3 "2L" 7 "Continuous" 15 1)
(_layer3 "3" 1 "Hidden" 15 1)
(_layer3 "4" 2 "Center" 15 1)
(_layer3 "SK1" 4 "Continuous" 15 1)
(_layer3 "SK2" 7 "Continuous" 15 1)
(_layer3 "SK3" 1 "Hidden" 15 1)
(_layer3 "SK4" 2 "Center" 15 1)
Share this post
Link to post
Lee Mac
Firstly, please use Code Tags when posting code.
You haven't copied the code correctly, the DXF group codes are wrong...
Share this post
Link to post
