guhan Posted July 13, 2012 Posted July 13, 2012 Hi, can I place a direction arrows on 3D polyline in dwg files? In 2D, it is very simple. Please I need your help. Thanks Quote
ReMark Posted July 13, 2012 Posted July 13, 2012 I don't see why you couldn't. Did you run into a problem attempting to do so? Quote
ReMark Posted July 14, 2012 Posted July 14, 2012 Post a copy of your drawing so we can take a look at it. Make sure the arrow block is included too. Quote
guhan Posted July 16, 2012 Author Posted July 16, 2012 Hi, i have attached a drawing file which is showing its direction by arrows. But my requirement is, showing the direction of 3D polyline also. Polyline with showing its direction.dwg Quote
eldon Posted July 16, 2012 Posted July 16, 2012 The information that you are giving is not quite right. You have a custom linetype called Direction, which does not work for 3D polylines. If you used an arrow block with the command Measure or divide, you would have no problem. Quote
eldon Posted July 16, 2012 Posted July 16, 2012 Yes, My arrow is a block. Then you have sent the wrong drawing. In the drawing posted, there are NO blocks. When I enabled linetype generation, some arrows do not stay on the line - typical behaviour of a complex linetype not properly formed. Quote
eldon Posted July 16, 2012 Posted July 16, 2012 Try exploding your 3D polyline and see what happens Quote
guhan Posted July 17, 2012 Author Posted July 17, 2012 Thanks to all.I got it. I posted the attachment for 2D polyline only. For 3D polyline, i am using block arrows with Measure or Divide command in Autocad. It is a better way to show the direction of 3D polyline. But this is also a long process. In my drawing file, i have drawn many 3D polylines (lines either closed or opened).I have to run the same command many times too. How can we get a solution for this problem? Quote
eldon Posted July 17, 2012 Posted July 17, 2012 3D polylines can only have a Continuous linetype, but 3D lines show the Linetype. If you must have 3D polylines, then your only solution is to use the arrow block as you are now doing. If you can make do with 3D lines, then explode the polylines. Quote
