sayhi_sanjay1 Posted July 18, 2012 Posted July 18, 2012 (defun c:DPH()(asave)(command "-layer" "m" "center" "lt" "center" "" "c" "8" "" "m" "pipe" "lt" "continuous" "" "c" "4" "" "")(command "MLINE" "S" "21.34" PAUSE PAUSE "")(command "explode" "l")(command "offset" "10.67" pause pause "" )(command "change" "l" "" "p" "la" "center" "c" "bylayer" "lt" "bylayer" "" "")) (defun c:DP3F()(asave)(command "-layer" "m" "center" "lt" "center" "" "c" "8" "" "m" "pipe" "lt" "continuous" "" "c" "4" "" "")(command "MLINE" "S" "26.67" PAUSE PAUSE "")(command "explode" "l")(command "offset" "13.34" pause pause "" )(command "change" "l" "" "p" "la" "center" "c" "bylayer" "lt" "bylayer" "" "")) Help to make Pipe in 2d double line Quote
