Creating non-grapical input inside drawing memory (dictadd??)
P Raja
Hi all...i would like to keep a record of non-graphical information's into a drawing. i would like to keep the records of drawing like
*Project number
*customer name &
*Revision number as a non graphical data inside the autocad.
i found that we can use "dictadd" to store data's inside a drawing and can retrieve from it at any time...
can anyone help me? how can i add a data by using "dictadd" and also advise how can i edit the stored data? (ex. incase i do revision 2, i need to change the revision number value)
Guest kruuger
; [DCT] ===================================================================================== ;
; cd:DCT_AddDict          - Dodaje slownik / Adds the dictionary                              ;
; cd:DCT_AddXrecord       - Dodaje Xrecord / Adds the Xrecord                                 ;
; cd:DCT_GetDict          - Pobiera slownik / Gets a dictionary                               ;
; cd:DCT_GetDictList      - Pobiera liste slownikow / Gets a list of dictionaries             ;
; cd:DCT_GetExtDict       - Pobiera/Tworzy ExtensionDict. / Gets/Creates an ExtensionDict.    ;
; cd:DCT_GetExtDictVLA    - Pobiera/Tworzy ExtensionDict. / Gets/Creates an ExtensionDict.    ;
; cd:DCT_GetXrecord       - Pobiera Xrecord / Gets Xrecord                                    ;
; cd:DCT_RemoveDict       - Usuwa slownik / Removes the dictionary                            ;
; cd:DCT_ReplaceXrecord   - Podmienia Xrecord / Replace Xrecord                               ;
; cd:DCT_SetXrecordVLA    - Zmienia Xrecord / Change Xrecord                                  ;
; Dodaje slownik / Adds dictionary                                                            ;
;  Root [ENAME/nil] - ENAME = slownik "rodzic" / "parent" dictionary                          ;
;                     nil   = (namedobjdict) jako "rodzic" / (namedobjdict) as "parent"       ;
;  Name [sTR]       - nazwa slownika / name of the dictionary                                 ;
; (cd:DCT_AddDict (namedobjdict) "NAZWA")                                                     ;
(defun cd:DCT_AddDict (Root Name)
 (dictadd (if (not Root) (namedobjdict) Root) Name
   (entmakex (append '((0 . "DICTIONARY")(100 . "AcDbDictionary"))))
; Dodaje Xrecord / Adds the Xrecord                                                           ;
;  XName [sTR]       - nazwa xrecord / xrecord name                                           ;
;  XData
[list]      - dane xrecord / xrecord data                                            ;
; (cd:DCT_AddXrecord (cd:DCT_GetDict (namedobjdict) "NAZWA") "NAZWA-SUB1" '((1 . "ABC")))     ;
(defun cd:DCT_AddXrecord (Root XName XData)
 (dictadd (if (not Root) (namedobjdict) Root) XName
   (entmakex (append '((0 . "XRECORD")(100 . "AcDbXrecord")) XData))
; Pobiera slownik / Gets a dictionary                                                         ;
; (cd:DCT_GetDict (namedobjdict) "NAZWA")                                                     ;
(defun cd:DCT_GetDict (Root Name)
 (cdr (assoc -1 (dictsearch (if (not Root) (namedobjdict) Root) Name)))
; Pobiera liste slownikow "rodzica" / Gets a list of "parent" dictionaries                    ;
;  Root [ENAME] - ENAME = slownik "rodzic" / "parent" dictionary                              ;
;  Code [T/nil] - T   = zwraca / returns -> ((<slownik1> . <ENAME1>) ... )                    ;
;                 nil = zwraca / returns -> (<slownik1> <slownik2> ... )                      ;
; (cd:DCT_GetDictList (cd:DCT_GetDict (namedobjdict) "NAZWA") T)                              ;
(defun cd:DCT_GetDictList (Root Code / dt tmp res)
 (if Root
   (if Code
       (setq dt (entget Root))
       (while
         (setq dt (member (setq tmp (assoc 3 dt)) dt))
         (setq res (cons (cons (cdr tmp) (cdadr dt)) res)
               dt (cdr dt)
       (setq res (reverse res))
     (setq res (cd:DXF_massoc 3 (entget Root)))
 res
; Pobiera/Tworzy ExtensionDictionary obiektu / Gets/Creates an ExtensionDictionary of object  ;
;  Obj  [ENAME/VLA-Object] - obiekt VLA lub entycja / VLA-Object or entity name               ;
;  Flag [T/nil] - T   = tworzy / creates                                                      ;
;                 nil = pobiera jesli istnieje / gets if exist                                ;
; (cd:DCT_GetExtDictVLA (car (entsel)) T)                                                     ;
(defun cd:DCT_GetExtDictVLA (Obj Flag / res)
 (if (= (type Obj) (quote ENAME))
   (setq Obj (vlax-ename->vla-object Obj))
 (if
   (setq res
     (if (= :vlax-true (vla-get-HasExtensionDictionary Obj))
       (vla-GetExtensionDictionary Obj)
       (if Flag (vla-GetExtensionDictionary Obj))
   (vlax-vla-object->ename res)
;  Ename [ENAME] - nazwa entycji / entity name                                                ;
; (cd:DCT_GetExtDict (car (entsel)) T)                                                        ;
(defun cd:DCT_GetExtDict (Ename Flag / res he ta)
 (if
   (and
     (= (type Ename) (quote ENAME))
     (setq dt (entget Ename))
   (if (not (setq res (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") dt)))))
     (if Flag
         (setq res (entmakex (append '((0 . "DICTIONARY") (100 . "AcDbDictionary"))))
               he (reverse (member (assoc 5 dt) (reverse dt)))
               ta (cdr (member (assoc 5 dt) dt))
         (entmod
           (append
             he
             (list
               (cons 360 res)
              '(102 . "}")
             ta
 res
; Pobiera Xrecord / Gets Xrecord                                                              ;
; (cd:DCT_GetXrecord (cdar (cd:DCT_GetDictList (cd:DCT_GetDict (namedobjdict) "NAZWA") T)))   ;
(defun cd:DCT_GetXRecord (Ename / dt)
 (cdr (member (assoc 280 (setq dt (entget Ename))) dt))
; Usuwa slownik / Removes the dictionary                                                      ;
; (cd:DCT_RemoveDict (namedobjdict) "NAZWA")                                                  ;
(defun cd:DCT_RemoveDict (Root Name)
 (dictremove (if (not Root) (namedobjdict) Root) Name)
; Podmienia Xrecord / Replace Xrecord                                                         ;
;  Ename [ENAME] - nazwa entycji xrecord / entity name xrecord                                ;
;  Data
[list]  - lista par kropkowych / list of dotted pairs                                ;
; (cd:DCT_ReplaceXrecord        ;
;   (cdar (cd:DCT_GetDictList (cd:DCT_GetDict (namedobjdict) "NAZWA") T))                     ;
;   (list (cons 1 "NEW") (cons 341 (car (entsel)))))                                          ;
(defun cd:DCT_ReplaceXrecord (Ename Data / en root name)
 (setq root (cdr (assoc 330 (entget Ename)))
       name (cdr
              (assoc
                Ename
                (mapcar
                  (function
                    (lambda (%)
                      (cons (cdr %) (car %))
                  (cd:DCT_GetDictList root T)
 (if (cd:DCT_RemoveDict root name)
     (setq en (cd:DCT_AddXrecord root name Data))
     (cd:DCT_GetXRecord en)
; Zmienia Xrecord / Change Xrecord                                                            ;
;  Data
; (cd:DCT_SetXrecordVLA        ;
;   (list (cons 1 "NEW123") (cons 341 (car (entsel)))))                                       ;
(defun cd:DCT_SetXrecordVLA (Ename Data / n)
 (setq n (1- (length Data)))
 (vla-SetXRecordData
   (vlax-ename->vla-object Ename)
   (vlax-make-variant
     (vlax-safearray-fill
       (vlax-make-safearray
         vlax-vbInteger
         (cons 0 n)
       (mapcar (quote car) Data)
   (vlax-make-variant
         vlax-vbVariant
         (cons 0 n)
       (mapcar
         (function
           (lambda (% / %1)
             (setq %1 (type %))
             (cond
               ( (= %1 (quote ENAME)) (vlax-ename->vla-object %))
               ( (= %1 (quote LIST)) (vlax-3d-point %))
               (T %)
         (mapcar (quote cdr) Data)
 (cd:DCT_GetXRecord Ename)
; Zwraca wartosc danego klucza z listy asocjacyjnej /                                         ;
; Returns the value of a key from assoc list                                                  ;
;  Key  [iNT]  - klucz / key        ;
;  Data
; (cd:DXF_Massoc 10 (entget (car (entsel))))                                                  ;
(defun cd:DXF_Massoc (Key Data / res tmp)
 (while
   (setq Data (member (setq tmp (assoc Key Data)) Data))
   (setq res (cons (cdr tmp) res)
         Data (cdr Data)
 (reverse res)
