moonh Posted July 26, 2012 Posted July 26, 2012 Hello, My question is "Can I create surfaces, profiles, & alignments using AutoCad2012?" I know if I had Civil3D2012 I could do it, but can it be done with the Regular version I should say. At my previous job I was using Civil3D2010 (darn economy Goverment job did lay offs) and now I'm using CAD2012 with new employer and I'm realizing that there are a lot of functions/commands that I don't have. Thank-you for taking time to look over my post A Young Civil Engineer determined to do great things one day. Quote
SLW210 Posted July 26, 2012 Posted July 26, 2012 Try the FREE CAD TOOLS for a start. Search for specific LISP files to help with anything else. Quote
Organic Posted July 26, 2012 Posted July 26, 2012 No, you can do none of those features you listed in plain AutoCad 2012 (or earlier/newer versions). As a civil engineer you really do need either AutoCad Civil 3D or some other civil design software package. You can always manually draw profiles in AutoCad by calculating the levels etc yourself although that is tedious and within probably a month it would have been cheaper for the company to pay for Civil 3D instead. Quote
moonh Posted July 26, 2012 Author Posted July 26, 2012 Dink Thank-You. That is what I thought, I just wanted to make sure, before I proposed purchasing Civil3D to my supervisors. Quote
moonh Posted July 26, 2012 Author Posted July 26, 2012 SLW, yes I saw your post and that is what I need for the current project I'm working on, but I work for a small goverment municipality and our MIS Dept. gave me a "NO GO" on permission to download. That is one difference I have realized between Public and Private Sector. Working in Public Sector any changes to the CPU must be approved by several supervisors, where as in Private Sector you have way more freedom. Thank-you for that link, it is a wonderful tool to know about. Quote
SLW210 Posted July 26, 2012 Posted July 26, 2012 Lots O'Luck getting the purchase of Civil 3D approved Quote
eea123 Posted September 9, 2012 Posted September 9, 2012 ... and this would be the same MIS Dept. that bought a seat of plain AutoCAD? Quote
Dadgad Posted September 9, 2012 Posted September 9, 2012 Try the FREE CAD TOOLS for a start. Search for specific LISP files to help with anything else. Damn, that is a nice link there SLW210, thanks! Quote
BIGAL Posted September 10, 2012 Posted September 10, 2012 Moonh are you producing plans from field data and if so are you using a total station ? Most of the newer ones have a dxf ability as a output file obviously helps. I would push the MIS staff write a request stating the facts about time savings if you could get one of the freebies, use sites like this as support that others have vetted the software. Theres a number of surface modler source code out there so you provide the code to your MIS to prove it will not harm your network. All I can say one particualr task 20mins now a couple of seconds. Quote
