the condition
Help needed
the condition
Hi, first of all.
Have a small question for someone who knows Solid, how to "cut the lump" in assembly composed of 2 parts like on image.
So, I need to smooth cylinder with eliptical cap shape.
Thx.
Picture:
Share this post
Link to post
JD Mather
Why not model as multi-body solids to begin with?
Share this post
Link to post
the condition
I'll give it a try, havent really used multi-body that much, I need it to be in 2. parts for further manifacturing, so I always sketched part by part
Share this post
Link to post
bhamze
Edit the part in context of the assembly. Create a 0 offset of surface, then use cut with surface to remove geometry from part. If you can provide a part and better explanation of what your trying to achieve I can provide an example.
Share this post
Link to post
JD Mather
You can push out the two individual parts when finished. Multi-body really simplfies stuff like this.
It does create an extra file - but all your dimensions are in one master file.
Share this post
Link to post
the condition
THX, multibody seems very useful.
Share this post
Link to post
the condition
half-coupling asme b16.11 1-2 6000 nipple.SLDPRT
It worked with multi-body, but I did similar in CATIA like you suggested, so I'm interested to learn that in Solid. I'll provide two parts in attachment.
podnica 152 R-taljan_donja.SLDPRT
Share this post
Link to post
bhamze
Is the attached what your trying to accomplish? If so, let me know and I will provide an example. If not, can you explain in better detail of what your trying to do?
Share this post
Link to post
the condition
yes, that's it
Share this post
Link to post
bhamze
Here you go. Does it help?
Share this post
Link to post
the condition
THX, video says more than words...untrim surface was something I missed before the video.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
