rolso Posted November 4, 2008 Posted November 4, 2008 I know what it does, it offsets a chosen line a given distance to either side of the original line and gives you the option of deleting the original. What is the full name for that command? It doesn't appear on the command line when you use the alias. TIA! Quote
smorales02 Posted November 4, 2008 Posted November 4, 2008 Im not sure but I dont have such command...or are you talking about just the "offset" command???? Quote
GhostRider Posted November 4, 2008 Posted November 4, 2008 I think it must be a custom command or lisp you have for "OL" I don't believe it is a standard command Quote
rolso Posted November 4, 2008 Author Posted November 4, 2008 Yeah, its part of a lisp command. Someone who no longer works here wrote it and when trying to use it on a new machine that is using 2009, it doesn't work properly. Quote
ReMark Posted November 4, 2008 Posted November 4, 2008 I thought I saw a similar lisp routine over at the CAD Corner if you're interested. Quote
GhostRider Posted November 5, 2008 Posted November 5, 2008 Rolso if you can, paste the lisp here and someone possible can sort out why it won't work... Quote
smorales02 Posted November 5, 2008 Posted November 5, 2008 i dont understand why a lisp like this is needed. is it really that hard to just use the offset command than just erase the line if you dont want it??? Quote
