KennethA Posted November 5, 2008 Posted November 5, 2008 I'm a bit confused with the new interface in Acad 09. How do I make .dwg's open in the same window I already have open? K. Quote
papagyi Posted November 5, 2008 Posted November 5, 2008 Do you means you can only open single dwg? Quote
succu8us Posted November 5, 2008 Posted November 5, 2008 maybe he's asking how to open multiple dwgs in autocad 09. i'm experiencing it also. when i open another dwg file, another autocad 09 will start. Quote
KennethA Posted November 5, 2008 Author Posted November 5, 2008 succu8us is right. When I open a .dwg, a new acad 09 starts. How do I set it to open in the current window? Its no problem in Acad 07. Quote
papagyi Posted November 5, 2008 Posted November 5, 2008 Right!SDI....(single drawing interface)...(0/1)...0(for multiple) 1(for single).. Quote
nocturne00 Posted November 5, 2008 Posted November 5, 2008 I'm a bit confused with the new interface in Acad 09. How do I make .dwg's open in the same window I already have open? K. Is your CAD2009 just recently installed and as default set that way? Its usually preset already to SDI=0 Quote
KennethA Posted November 5, 2008 Author Posted November 5, 2008 Thanks alot for the answers. It came with Inventor 2009, but I have not used it before now, because I usually draw 2D with 2007 LT. It was installed like this. Quote
KennethA Posted November 5, 2008 Author Posted November 5, 2008 Well, that didn't work. I typed in SDI and the preset was already at 0. I tried both 1 and 0 but it still opens files in a new Acad application. Quote
dbroada Posted November 5, 2008 Posted November 5, 2008 I don't have 2009 (installed) but I think you need to set TASKBAR = 1 too. There have been some recent posts. Quote
NBC Posted November 5, 2008 Posted November 5, 2008 I have TASKBAR = 0, and SDI = 0 and these seem to work fine Quote
