How to do gear dynamic analysis? (Problem of insert joint part)
zmarcoz
 Share
I am creating my first very simple gears for learning dynamic analysis. I followed a youtube video to create two gears, then I try to run the analysis. When I create a cylinder-to-cylinder joint, it asks for the cylinders (which are the gears) and the origins of those gears. I can set the gears easily, but I cannot set the origins. Please help. I attached the assembly file here. :oops:
Sorry that the forum do not take *.iam file, so I zip the file
Assembly1.zip
 Share
