PaulS00 Posted August 27, 2012 Posted August 27, 2012 Hello, So when using C3D, I have my right-click setup so that when I click on an object, say a multi-leader, surface, etc, a long menu pops up with object-specific options. Such as multi-leader styles and scales, pipe network options, etc. So today, AutoCAD decided to be lazy and not show that menu. I've tried turning off the R-C customization, then turning it back on, switching the custom options around, applying, then setting them back to the way I had them, starting a new drawing, restarting CADD, and finally restarting my computer. NOTHING. This has happened to me several times in the past and it just starts working properly again at some point. To draft, modifying C3D objects, without the r-c menu is such a time consuming PITA. Thoughts? Quote
PaulS00 Posted August 27, 2012 Author Posted August 27, 2012 N/M. I was going through the Options tabs and found the "Noun/Verb Selection." I remembered someone talking about this on this forum or another. It was unchecked, don't know how. I checked the box and voila! Quote
