nod684 Posted September 25, 2012 Posted September 25, 2012 I have been using this Lisp (attached) before without any dialog box appearing. I have a lot of lisp that i used without the dialog box appearing. I understand that i can edit the LISP and put -sign on the commands to suppress the dialog boxes. But i have a lot and tracing each one of then is time consuming But now, all of a sudden, when i used these Lisp (any some of my lisp too) dialog box appears! what could have happen? I couldn't trace which setting or system variable was changed I've tried Filedia (but i need filedia set to 1) Attdia is for attributes Expert is set to 3 any ideas? RBLOCK.LSP MNL.lsp Quote
Tiger Posted September 25, 2012 Posted September 25, 2012 Well, the variable that controls dialogue boxes is FILEDIA - perhaps something else changed your default setting for the variable? Quote
nod684 Posted September 25, 2012 Author Posted September 25, 2012 Well, the variable that controls dialogue boxes is FILEDIA - perhaps something else changed your default setting for the variable? its working fine before eventhough FILEDIA is set to 1 i need it set to 1 for easy opening and saving of dwgs. any other sysvar related to this? Quote
nod684 Posted September 25, 2012 Author Posted September 25, 2012 Finally found the answer! QAFLAGS must be set to 0 i ran a lisp i've downloaded somewhere and it sets QAFLAGS to 1 and does not reset it back. Quote
Tiger Posted September 25, 2012 Posted September 25, 2012 Huh. That's a new one! And I don't find anything in Help or SYSVDLG about it either. Glad you found it mate Quote
nod684 Posted September 25, 2012 Author Posted September 25, 2012 Huh. That's a new one! And I don't find anything in Help or SYSVDLG about it either. Glad you found it mate Yes its not even on the HELP i've googled it and says its Undocumented System Variable http://www.manusoft.com/resources/acadexposed/sysvars.html Quote
