Default Name on PDF print
I couldn't find this anywhere so maybe someone has an answer...
When you print to a PDF in Map 2009 3D the format is as follows:
DrawingName LayoutName (1)
I was wondering if anyone knew of a way to make it so the default name is simply the name of the layout tab. Otherwise every tab that I export has to be changed in the save as dialog (which can become very time consuming with lots of layouts).
i believe the answer to that is "negatory" my friend....looked through all the settings and printer defaults and i dont believe it can be changed
