woodman78 Posted October 17, 2012 Posted October 17, 2012 I have this lisp that I modified from on that LeeMac wrote for me to update the text on dimensions. I was looking to make it work for leaders but I haven't got it working. Can an option be added to set the width of the multiline text for the leader as well? leader_update : dialog { key = "dctitle"; spacer; : list_box { label = "Notes:"; key = "lst"; alignment = centered; fixed_height = true; fixed_width = true; width = 50; height = 20; } spacer; ok_cancel; } (defun c:leader_update ( / *error* _read ) ;; © Lee Mac 2010 (setq dcfilename "leader_update.dcl" ;; DCL Filename Strfilename "CCC_NNRDO_leader_update.txt" ;; Data Filename ) (defun *error* ( msg ) (and dcTag (unload_dialog dcTag)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) (defun _read ( file / ofile lst nl ) (cond ( (setq ofile (open file "r")) (while (setq nl (read-line ofile)) (setq lst (cons nl lst))) (close ofile))) (reverse lst) ) (cond ( (not (setq Strfilename (findfile Strfilename))) (princ "\n** Data File not Found **")) ( (not (setq StrLst (_read Strfilename))) (princ "\n** Data File Empty **")) ( (not (setq ss (ssget "_:L" '((0 . "*LEADER")))))) ( (<= (setq dcTag (load_dialog dcfilename)) 0) (princ "\n** Dialog Definition Not Found **")) ( (not (new_dialog "leader_update" dcTag)) (princ "\n** Dialog Could not be Loaded **")) (t (start_list "lst") (mapcar (function add_list) StrLst) (end_list) (set_tile "dcltitle" "Dimension Notes") (setq ptr (set_tile "lst" "0")) (action_tile "lst" "(setq ptr $value)") (setq dcFlag (start_dialog) dcTag (unload_dialog dcTag) Str (nth (atoi ptr) StrLst)) (if (= 1 dcFlag) ( (lambda ( i ) (while (setq ent (ssname ss (setq i (1+ i)))) (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat str)) (assoc 1 (entget ent)) (entget ent)) ) ) ) ) ) ) -1 ) (princ "\n*Cancel*") ) ) ) (princ) ) Thanks. CCC_NNRDO_Leader_update.txt leader_update.dcl Quote
woodman78 Posted October 18, 2012 Author Posted October 18, 2012 I found this lisp below at the following location: http://lispcad.com/2012/03/add-leader-to-text-%E2%80%93-make-multileader/ Can this be modified to create an mleader based on a style when a text string is selected from the dcl window? (defun c:mt2ml ( / oobj nobj nstrg) (vl-load-com) (setq oobj (vlax-ename->vla-object (car (nentsel "nSelect source text: ")))) (if (= (vlax-get-property oobj 'ObjectName) "AcDbMText") (setq nstrg (vlax-get-property oobj 'TextString)) (exit) ) (command "_MLEADER") (while (= 1 (logand (getvar "CMDACTIVE") 1)) (command PAUSE)) (setq nobj (vlax-ename->vla-object (entlast))) (if (= (vlax-get-property nobj 'ObjectName) "AcDbMLeader") (vlax-put-property nobj 'TextString nstrg) (exit) ) (entdel (vlax-vla-object->ename oobj)) (princ) ) Quote
woodman78 Posted October 22, 2012 Author Posted October 22, 2012 I have taken a different approach to this now. I have created blocks with leaders and the specific text I want but how do I get this lisp that LeeMac helped me with to explode the blocks on input? I have researched that I need to put star before the name but how do I do this when I can select multiple blocks? insert_lining_leaders : dialog { //*dialog name label = "Lining Leaders"; //*give it a label : row { //*define row : paragraph { //*define paragraph } //*end paragraph } //*end row : row { //*define row : boxed_column { //*define boxex_column label = "Choose a Note:"; //*give it a label : list_box { //*define popup_list key = "S1"; //*give it a name width=100; //*edit_width fixed_width=true; //*fixed width height=20; //*Height fixed_height=true; //*fixed height alignment = right; //*alignment multiple_select=true; } //*end popup_list : spacer { //*define spacer height = 0; //*height } //*end spacer } //*end boxed_column } //*end row : row { //*define row : column { //*define column ok_cancel ; //*predifined OK/Cancel : paragraph { //*define paragraph : text_part { //*define more text label = "CCC NNRDO v1.0.24.07.2009"; //*some more text } //*end text } //*end paragraph } //*end column } //*end row } //*end dialog (defun c:insert_lining_leaders (/ *error* DCHANDLE INPT OV PT RTN S1_LIST VL SUSM) (setq SUSM (getvar "osmode")) (defun *error* (msg) (and dcHandle (unload_dialog dcHandle)) (and ov (mapcar 'setvar vl ov)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) (setq S1_list '("*** Smybols ***" ;0 "M115 Yield Triangle" ;1 ) ) (setq vl '("CMDECHO" "CLAYER" "OSMODE") ov (mapcar 'getvar vl)) (setvar "attdia" 1) (cond ( (<= (setq dcHandle (load_dialog "insert_lining_leaders.dcl")) 0) (princ "\n** Dialog file not Found **")) ( (not (new_dialog "insert_lining_leaders" dcHandle)) (princ "\n** Dialog Definition Not Found **")) (t (start_list "S1") (mapcar (function add_list) S1_list) (end_list) (set_tile "S1" (setq *def* (cond (*def*) ("1")))) (action_tile "S1" "(setq *def* $value)") (action_tile "accept" "(cond ((member (atoi *def*) '(0)) (alert \"Invalid Note\")) ((done_dialog 1)))") (action_tile "cancel" "(done_dialog 0)") (setq rtn (start_dialog)) (setq dcHandle (unload_dialog dcHandle)) (if (= 1 rtn) (progn (or (tblsearch "LAYER" "CCC_SHEET_LAYOUT_Notes") (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 "CCC_SHEET_LAYOUT_Notes") (cons 70 0) (cons 62 7) (cons 370 30)))) (mapcar 'setvar vl '(0 "CCC_SHEET_LAYOUT_Notes" 0)) (foreach block (mapcar (function (lambda (x) (nth x S1_list))) (read (strcat "(" *def* ")"))) (setvar "osmode" 1) (if (setq pt (setq INPT (getpoint "\nPick Insertion Point: "))) (command "_.-insert" block INPT "1" "1" "0")))) (princ "\n*Cancel*")))) (setvar "osmode" SUSM) (setvar "attdia" 0) (mapcar 'setvar vl ov) (princ)) Quote
