Lentezza Posted October 23, 2012 Share Posted October 23, 2012 Hello, I attached the drawing to make it more easy... I have this classic kitchen situation: two boards (in the drawing one is a box, the other a extruded polyline) forming an inner corner. While chamfering all the outside edges I come across one edge (in the drawing the long one of the long board) where I want to chamfer the edge only from the right corner to the point where the two boards meet. How can I do this??? Thanx Len I Küche C & M 1.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 Is this the result you were looking to obtain? Quote Link to comment Share on other sites More sharing options...
Lentezza Posted October 23, 2012 Author Share Posted October 23, 2012 Basically yes, but I need the two boards to remain seperate. Thank you! Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 Then slice the board. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 This outside corner doesn't look right to me. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted October 23, 2012 Author Share Posted October 23, 2012 Sliced it, using SLICE. This cut off one part of the board removing it so I had to go back and make a copy of that part before UNION. All this worked however to arrive at the desired result. Is there a better way for slicing? Which only cuts in two halfs? Quote Link to comment Share on other sites More sharing options...
Lentezza Posted October 23, 2012 Author Share Posted October 23, 2012 What´s wrong about the corner? Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 Sliced it, using SLICE. This cut off one part of the board removing it so I had to go back and make a copy of that part before UNION. All this worked however to arrive at the desired result. Is there a better way for slicing? Which only cuts in two halfs? Yes. You could construct each board separately which I did not think was a requirement when I posted my first image. Now there are two. And "yes" it maintains the beveled inside corner. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 What´s wrong about the corner? In my opinion it should not have that flat face we see. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 23, 2012 Share Posted October 23, 2012 Is there a better way for slicing? Which only cuts in two halfs? When you use Slice you are given the option to keep both sides. Read your command line. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 I think the outside corner should look like this. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted October 23, 2012 Author Share Posted October 23, 2012 In my opinion it should not have that flat face we see. I undertand. No, that´s perfect the way it is. Küche C & M.dwg Quote Link to comment Share on other sites More sharing options...
Lentezza Posted October 23, 2012 Author Share Posted October 23, 2012 When you use Slice you are given the option to keep both sides.Read your command line. I should really do this! Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 Sorry but I don't think that is how the shop would make that inside corner. It looks OK but fabrication-wise I think it does not work. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 The portion of the corner circled in black seems like it would be a pain to cut into the countertop. Should the yellow part of the counter be cut in such a way as to create a 45 deg angle? Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 Your corner - top view. My corner - top view. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted October 23, 2012 Author Share Posted October 23, 2012 Actually the drawing is not meant for the shop but for the customer. I am going to do a drawing for the shop later, but there I won´t put the beveling and won´t have to worry about it. I am curios anyway how they are going to do this detail. When I produce a thing like this in solid wood I mostly do it the way it is in my drawing and I finish the very corner manually. These boards thought are going to be made of stone. Your solution is defintely more elegant but in practice would be done only with a beveling of bigger dimensions as it is also quite complex in production. Thank you once again for your support and have a good day! Quote Link to comment Share on other sites More sharing options...
