Layer Create or Set Current if already existing
clint0577
I have a routine that I've been using but I would like to modify it just a bit. The function is for creating Deed Sketches that allows the user to create a new layer and select a color. It works great but if you happen to exit the command, and need to start again, it still asks for a new layer. I would like to change the code to have the option to first, USE THE CURRENT LAYER. If not then I would have the option I already have, which is to create the new layer but then I need to, if that layer already exists, set it to current. Here is that portion of the code. I've tried tons of different ways but I know just enough about lisp routines to get myself into trouble.
;main program
(DEFUN C:deed ()
(while
(or
(not (snvalid (setq name (getstring t "\nSpecify Layer Name: "))))
(tblsearch "LAYER" name)
(princ "\nLayer Name Invalid or Already Exists.")
(if (setq color (acad_colordlg 7 nil))
(entmake
(list
(cons 0 "LAYER")
(cons 100 "AcDbSymbolTableRecord")
(cons 100 "AcDbLayerTableRecord")
(cons 2 name)
(cons 70 0)
(cons 62 color)
(command "layer" "s" NAME "")
Hi,
Modify While loop as below.
This will checks the layer name for vlididty. It it is a valid layer then checks weather it already exists or Not.
If the layer exists sets the layer as current layer.
I hopes this works for you.
(DEFUN C:deed ()
(setq newlayer T)
(while (not (setq name (getstring t "\nSpecify Layer Name: ")))
(if (tblsearch "LAYER" name)
 (progn (command "Layer" "S" name "") (setq newlayer nil))
 (princ "\nLayer Name Invalid.")
(if newlayer
     (entmake
(list
  (cons 0 "LAYER")
  (cons 2 name)
  (cons 70 0)
  (cons 62 color)
Welcome to the forum. :)
What you are trying to do, while not exactly the same,
brings to mind one of my very favorite lisps, which runs nonstop on my machines.
That is Lee Mac's LAYER DIRECTOR.
Thanks Lee! :beer:
Everybody should use this lisp, it is simply brilliant, and very easily modified to suit personal needs,
even by those who are lisp-challenged, like myself.
This is but one of a great many wonderful lisps generously made available
on Lee's site. Do yourself a favor, check them out. :thumbsup:
Edited by Dadgad
