Shawpelganger Posted November 22, 2012 Share Posted November 22, 2012 Whenever I use the move command on a line or series of lines that are touching other lines, the lines that aren't part of my selection move with that one line. Here's a series of screenshots showing what I mean. I can't move just that line without moving the other lines around it. Quite frustrating. Anybody know how to fix this? Thanks! Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 27, 2012 Share Posted November 27, 2012 Did you resolve your problem? Quote Link to comment Share on other sites More sharing options...
Shawpelganger Posted November 27, 2012 Author Share Posted November 27, 2012 I sort of solved it I think. If I select all my lines and type "delconstraint" then the move command works correctly. Once in a while I have to do that command again. I'm sure theres a way to turn off constraints completely but I'm not sure how. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 27, 2012 Share Posted November 27, 2012 Try setting the following system variable to a value of "0". Do so at the command line. Type: _CONSTRAINTINFER Quote Link to comment Share on other sites More sharing options...
