ShadabKhan Posted December 14, 2012 Share Posted December 14, 2012 I am Revit User I want to Design Tunnel in Revit is It Possible. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 14, 2012 Share Posted December 14, 2012 REVIT "Autodesk® Revit® software is specifically built for Building Information Modeling (BIM), helping building professionals design, build, and maintain higher-quality, more energy-efficient buildings." Why would you use Revit to build a tunnel? What kind of tunnel are you talking about? Would it be for vehicles or is this "tunnel" more like a passageway that utilities like steam, water, electric might be run through? We need more information. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted December 15, 2012 Author Share Posted December 15, 2012 Hi, Thanks for your reply, I would like to create tunnel for vehicle and i want to create under groung tunnel for metro and other vehicle. My client asking me that he can use Revit Structure for Tunnel design and tunnel structure. also have attached a file of curved beam detailing. can we give curved beam rebar detailing in revit Structure and how? he has given me tunnel profile i am attaching dwg file kindly see. Thanks, REVIT "Autodesk® Revit® software is specifically built for Building Information Modeling (BIM), helping building professionals design, build, and maintain higher-quality, more energy-efficient buildings." Why would you use Revit to build a tunnel? What kind of tunnel are you talking about? Would it be for vehicles or is this "tunnel" more like a passageway that utilities like steam, water, electric might be run through? We need more information. STD-TMPL-BT_2451.dwg PCS_REINFORCEMENT-SEGMENTS-TYPE B.dwg Quote Link to comment Share on other sites More sharing options...
Organic Posted December 15, 2012 Share Posted December 15, 2012 Personally I think this is beyond the scope of the software and by the sounds of it, your expertise level also. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted December 15, 2012 Author Share Posted December 15, 2012 Thanks, Would you suggest any other software for design and detailing of tunnels. Thanks, Personally I think this is beyond the scope of the software and by the sounds of it, your expertise level also. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 15, 2012 Share Posted December 15, 2012 (edited) FYI the reinforcement drawing which THINKS it is drawn in mms? It is really drawn in INCHES, as revealed by running the -DWGUNITS command. If you use the -DWGUNITS command at the commandline, (hit F2 before running the command) the prompts will walk you through resetting the database & insert units, and a bunch of other stuff, and it will rescale the drawing to the correct actual 1:1 full size. Safe to guess the other one may be similarly afflicted, but I didn't open it, so strictly conjecture. I'm guessing this won't be dug by one of those gigantic tunnel boring machines. I'm trying to figure out all of the different types of commercial enterprise, individuals, and such that might reasonably require the building of unregulated & undocumented tunnels, in the still of the night? Good luck, hoping you don't need it. Edited December 16, 2012 by Dadgad Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 15, 2012 Share Posted December 15, 2012 Thanks,Would you suggest any other software for design and detailing of tunnels. Thanks, CAr-D-Tel? Sorry, the Devil made me say that. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted December 15, 2012 Share Posted December 15, 2012 Revit Structure is more than capable of designing the examples shown in the DWG files. Just use a normal Extrusion on a profile, then use the Rebar tool to place all your reinforcements. Align some of the beams and done. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted December 16, 2012 Author Share Posted December 16, 2012 Dear, I got this drawing from my client and whatever method they are using to draw this drawing i dont know. they are asking me that curved beam reinforcement detail is possible in Revit Structure or not. can you please guide me is it possible in Revit Structure. Thanks, FYI the reinforcement drawing which THINKS it is drawn in mms?It is really drawn in INCHES, as revealed by running the -DWGUNITS command. If you use the -DWGUNITS command at the commandline, (hit F2 before running the command) the prompts will walk you through resetting the database & insert units, and a bunch of other stuff, and it will rescale the drawing to the correct actual 1:1 full size. Safe to guess the other one may be similarly afflicted, but I didn't open it, so strictly conjecture. I'm guessing this won't be dug by one of those gigantic tunnel boring machines. I'm trying to figure out all of the different types of commercial enterprise, individuals, and such that might reasonably require the building of unregulated & undocumented tunnels, in the still of the night? Good luck, hoping you don't need it. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted December 16, 2012 Author Share Posted December 16, 2012 Hi, I am trying to give the reinforcement details and facing lots of problem you have some tutorials or vedio to give curved reinforcement detail in Beam. Thanks, Revit Structure is more than capable of designing the examples shown in the DWG files. Just use a normal Extrusion on a profile, then use the Rebar tool to place all your reinforcements. Align some of the beams and done. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 16, 2012 Share Posted December 16, 2012 Dear,I got this drawing from my client and whatever method they are using to draw this drawing i dont know. they are asking me that curved beam reinforcement detail is possible in Revit Structure or not. can you please guide me is it possible in Revit Structure. Thanks, I am not REVIT savvy, but Stykface certainly is, and he has given a brief overview of the techniques one might want to use to accomplish this using Revit in his post. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted December 16, 2012 Share Posted December 16, 2012 Hi, I am trying to give the reinforcement details and facing lots of problem you have some tutorials or vedio to give curved reinforcement detail in Beam.Use the Detail Line or Model Line tool to create your Arc: Start the Beam tool. Use the Pick Lines option: Now select the line. Easy as pie. As for your Rebar, you can use the Rebar tools but my suggestion would be simply to just draw it in with 2D Linework once you've got your sections and other Views set up. Revit doesn't have to be 100% 3D all the time. Just utilize the 3D functionality the best you can then polish it off with 2D Linework. As you get more familiar with the program, you'll start attempting more sophisticated tools that Revit has to offer. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted December 16, 2012 Author Share Posted December 16, 2012 Thanks dear, but I am talking about concrete beam as per AutoCAD Drawing which I uploaded. I have Draw Beam but Unable to give Rebar Detail in curved concrete Beam. Thanks, Use the Detail Line or Model Line tool to create your Arc: Start the Beam tool. Use the Pick Lines option: Now select the line. Easy as pie. As for your Rebar, you can use the Rebar tools but my suggestion would be simply to just draw it in with 2D Linework once you've got your sections and other Views set up. Revit doesn't have to be 100% 3D all the time. Just utilize the 3D functionality the best you can then polish it off with 2D Linework. As you get more familiar with the program, you'll start attempting more sophisticated tools that Revit has to offer. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted December 16, 2012 Share Posted December 16, 2012 I just explained to not worry about the reinforcement. If you want to attempt it, then that's fine, but use the Sketch method instead. Revit Help has a lot of detailed explanation regarding Rebar. But, once again, I'll suggest to not worry about the Rebar Tool as it will only cause major problems and frustrate you, due to the nature of this type of design. You have to crawl before you can walk and you're attempting some very complicated reinforcement tasks. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted December 16, 2012 Author Share Posted December 16, 2012 Dear, Kindly see attached file. I want to give rebar detail in curved concrete beam. Thanks, Use the Detail Line or Model Line tool to create your Arc: Start the Beam tool. Use the Pick Lines option: Now select the line. Easy as pie. As for your Rebar, you can use the Rebar tools but my suggestion would be simply to just draw it in with 2D Linework once you've got your sections and other Views set up. Revit doesn't have to be 100% 3D all the time. Just utilize the 3D functionality the best you can then polish it off with 2D Linework. As you get more familiar with the program, you'll start attempting more sophisticated tools that Revit has to offer. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted December 16, 2012 Share Posted December 16, 2012 If all you're doing is using Stirrup Rebars then just use the Maximum Spacing option so it spans all the way across the beam. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted December 18, 2012 Author Share Posted December 18, 2012 Hi, I want to create Truss in my Circular Beam. How can i do this??? Kindly see attached file. Thanks, If all you're doing is using Stirrup Rebars then just use the Maximum Spacing option so it spans all the way across the beam. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted December 18, 2012 Share Posted December 18, 2012 I'd be at a loss if you're trying to literally use the Truss Tool. I'm no pro by any means. I would suggest just modeling it on a manual basis to start with. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted December 19, 2012 Author Share Posted December 19, 2012 Hi, I am Trying to creat cross beam between two beam it is not creating due to curved beam. I have use reference plan, sweep command but problem is still. can you please try it to create cross I section Beam. Thanks, I'd be at a loss if you're trying to literally use the Truss Tool. I'm no pro by any means. I would suggest just modeling it on a manual basis to start with. Quote Link to comment Share on other sites More sharing options...
