084x4larry
printer options
084x4larry
what is the process to get the autocad print/plot dialogue box to open up already choosing a certain printer out of the available ones you may have?
Share this post
Link to post
RobDraw
Page set up.
Share this post
Link to post
084x4larry
Page set up.
Appreciate the response but its so vague im not sure what u mean. but when i invoke plot in an autocad session i immeditatly get a warning about it not finding the driver for some printer... i then have to skip that warning and then go in the print dialogue box and manually scroll through all my available printers and pick the one that i use 99% of the time. i know theres a way to make it already have that one chosen as soon as i invoke the print command...
Share this post
Link to post
RobDraw
Sorry, with this in the "Drawing Management & Output" forum, I assumed you new what "page set up" meant.
This is happening because the "page set up" is calling for a printer you do not have. You need to save the file with a proper "page set up" that calls for your printer. You can either apply the settings to the "page set up" from the plot dialog box or from the "page set up" dialog.
Share this post
Link to post
084x4larry
that worked. thanks. only problem is any drawing that was not saved that way will still come up asking for stuff not available... guess theres no way around that. but what u said worked. thanks again!
Share this post
Link to post
BIGAL
1 Set up your DWT with the page setup in it set all your plot paraemeter then using "apply to layout" clicked, save this plot setup with a name then simply hit cancel the plot set up is remembered.
2 Do plot, Click on the page setup top left, at bottom is "import" so you can open the page setup from another dwg and bring it in.
3 after 2 if plotting multiple layouts got top left and click "previous plot" "apply to layout" and save dwg as normal.
Share this post
Link to post
RobDraw
I think there is a way to assign a printer to replace one that is not present instead of AutoCAD's default to go to the None printer, but I cannot find it at the moment.
Share this post
Link to post
lesleys
Hi not sure what your options are in 2011 but if you go to "options" do you get a plot publish tab? You can in the later version set your default printer there. I'm not sure if this will change your default printer for any other software though.
Share this post
Link to post
RobDraw
That alone does not change AutoCAD behavior of switching to the "None" printer when the assigned printer is not available.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
