John Posted November 12, 2008 Share Posted November 12, 2008 I created a block using symbol builder. The problem is the handle is way to the left. How can I get the handle back onto the block? I tried to use block editor but I can't find were the handle attribute is. Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 12, 2008 Share Posted November 12, 2008 I have no idea what symbol builder is but using BEDIT, open your block. Select all the parts and M(ove) from a sensible part to 0,0. If nothing moves you may have to type #0,0 as the displacement. Close the editor and your block will jump but its grip will be in the correct place. Quote Link to comment Share on other sites More sharing options...
John Posted November 12, 2008 Author Share Posted November 12, 2008 Sorry I should have specified I'm using AutoCAD Electrical 2008 Quote Link to comment Share on other sites More sharing options...
rookie37 Posted November 12, 2008 Share Posted November 12, 2008 I don't know how to move the handle point in bedit or know if you can. I do it another way. Im sure there is probably an easier way but don't know how Lets say capasitor 1 has the handle point in the wrong spot. It is 5m too high and 10m too far to the left go into capasitor 1.dwg move everything 5m up and 10m left save drawing I guess you can do the same in bedit but it won't update the wblock Quote Link to comment Share on other sites More sharing options...
rookie37 Posted November 12, 2008 Share Posted November 12, 2008 Im sure there is probably an easier way but don't know how I posted too quick and didn't read dbroada's post yet Quote Link to comment Share on other sites More sharing options...
